[GRASS-PSC] GitHub supports limiting open PRs per user
Veronica Andreo
veroandreo at gmail.com
Thu Aug 20 05:18:56 PDT 2026
Perhaps a topic to add here:
https://grasswiki.osgeo.org/wiki/PSC_Meeting_2026-08-14 for the meeting
tomorrow
El jue, 20 ago 2026 a las 7:52, Edouard Choinière via grass-psc (<
grass-psc at lists.osgeo.org>) escribió:
> For now, to avoid a situation where we would get stormed by a single user
> (and help with the cleanup afterwards), the limit I had set when the
> setting came out is 20 (to not bother existing collaborators too much). We
> can choose a number between 1 and 1000.
> We can also add users to a bypass list. I didn’t do anything on that,
> unless I had gotten feedback about the friction. That way we are still
> “protected” by an account being hijacked, even if was one of the closer
> collaborators.
> Edouard Choinière
> Le 20 août 2026 à 06:46, Linda Karlovská via grass-psc <
> grass-psc at lists.osgeo.org> a écrit :
> Hi everyone,
> I just found out that GitHub now has a setting that allows us to limit the
> number of open PRs a user can have in a repository.
> https://github.blog/changelog/2026-06-17-limit-open-pull-requests-for-users-without-write-access/?utm_source=chatgpt.com
> We can set a maximum number of open PRs per user, and there should also be
> an option to create a bypass list for trusted contributors.
> We talked about the increasing number of PRs with Anna and Vashek some
> time ago, so maybe we should consider trying this for GRASS.
> It might also potentially improve the quality of contributions if someone
> can only have, say, two or three PRs open at a time, they might be more
> likely to think about what really belongs in GRASS and what might be
> unnecessary.
> Best,
> Linda
> grass-psc mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-psc
Dra. Verónica Andreo
Investigadora Adjunta de CONICET
Instituto Gulich (CONAE - UNC)
Centro Espacial Teófilo Tabanera (CETT)
Falda del Cañete - Córdoba, Argentina
+54 3547 400000 int. 1153
https://veroandreo.gitlab.io/
URL: <http://lists.osgeo.org/pipermail/grass-psc/attachments/20260820/cf959400/attachment-0001.htm>
More information about the grass-psc
