SOCCER LAB GRASS QA: no clones 3 monsters and 3 warnings
cvs at proxy.soccerlab.polymtl.ca
Sun Apr 2 11:23:28 EDT 2006
Hello cho,
Threshold GRASS6 key metrics values at 2006-04-02 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 78 |
LOC: 40 | 182 | 254 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
ANALYSIS
./grass6/vector/v.in.dxf/make_arc.c functions
make_arc (Begins at: 11 Ends at: 99)
Complexity: | 9 | | OK |
ParamNBR: | 8 | ** | Warning |
CalledNBR: | 18 | | OK |
LOC: | 89 | | OK |
1 metric are OUT OF RANGE!
make_arc_from_polyline (Begins at: 101 Ends at: 198)
Complexity: | 13 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 21 | | OK |
LOC: | 98 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Brought to you by:
