SOCCER LAB GRASS QA: no clones 5 monsters and 3 warnings
cvs at proxy.soccerlab.polymtl.ca
Sun Apr 2 11:23:28 EDT 2006
Hello markus,
Threshold GRASS6 key metrics values at 2006-04-02 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 78 |
LOC: 40 | 182 | 254 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
ANALYSIS
./grass6/vector/v.in.ascii/points.c functions
is_int (Begins at: 12 Ends at: 20)
Complexity: | 4 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 9 | | OK |
metrics are OK
is_double (Begins at: 24 Ends at: 46)
Complexity: | 6 | | OK |
LOC: | 23 | | OK |
metrics are OK
points_analyse (Begins at: 48 Ends at: 185)
Complexity: | 18 | * | |
ParamNBR: | 11 | *** | MONSTER |
CalledNBR: | 39 | * | |
LOC: | 138 | * | |
1 metric are OUT OF RANGE!
points_to_bin (Begins at: 187 Ends at: 300)
Complexity: | 15 | | OK |
ParamNBR: | 13 | *** | MONSTER |
CalledNBR: | 53 | * | |
LOC: | 114 | * | |
Clone analysis:
This file does not contain cloned functions
Brought to you by:
