SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Apr 4 09:09:36 EDT 2006
Hello glynn,
Threshold GRASS6 key metrics values at 2006-04-04 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      78 |
LOC:                    40 |       182 |     254 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
ANALYSIS
./grass6/lib/gis/remove.c functions
G_remove (Begins at: 45 Ends at: 68)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
recursive_remove (Begins at: 72 Ends at: 98)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
Clone analysis:
Brought to you by:
