SOCCER LAB GRASS QA: no clones 0 monsters and 1 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Apr 4 09:09:36 EDT 2006
Hello radim,
Threshold GRASS6 key metrics values at 2006-04-04 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      78 |
LOC:                    40 |       182 |     254 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
ANALYSIS
./grass6/general/g.parser/main.c functions
parse_toplevel (Begins at: 28 Ends at: 57)
Complexity:   |       6 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
parse_module (Begins at: 59 Ends at: 82)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
parse_flag (Begins at: 84 Ends at: 124)
Complexity:   |       7 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      41 |       |      OK |
metrics are OK
parse_type (Begins at: 126 Ends at: 141)
CalledNBR:    |       4 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
parse_boolean (Begins at: 143 Ends at: 155)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
parse_option (Begins at: 157 Ends at: 239)
Complexity:   |      14 |       |      OK |
CalledNBR:    |      26 |       |      OK |
LOC:          |      83 |       |      OK |
metrics are OK
main (Begins at: 241 Ends at: 354)
CalledNBR:    |      35 |     * |         |
LOC:          |     114 |     * |         |
metrics are OK
Clone analysis:
Brought to you by:
