SOCCER LAB GRASS QA: no clones 7 monsters and 2 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Apr 4 09:25:47 EDT 2006
Hello markus,
Threshold GRASS6 key metrics values at 2006-04-04 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      78 |
LOC:                    40 |       182 |     254 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
ANALYSIS
./grass6/vector/v.transform/main.c functions
main (Begins at: 38 Ends at: 223)
Complexity:   |      13 |       |      OK |
CalledNBR:    |      87 |   *** | MONSTER |
LOC:          |     186 |    ** | Warning |
1 metric are OUT OF RANGE!
Clone analysis:
Brought to you by:
