SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Apr 4 10:56:24 EDT 2006
Hello markus,
Threshold GRASS6 key metrics values at 2006-04-04 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      78 |
LOC:                    40 |       182 |     254 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
ANALYSIS
./grass6/raster/r.thin/main.c functions
main (Begins at: 24 Ends at: 61)
Complexity:   |       2 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      38 |       |      OK |
metrics are OK
Clone analysis:
Brought to you by:
