SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Apr 4 14:39:17 EDT 2006
Hello cho,
Threshold GRASS6 key metrics values at 2006-04-04 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      78 |
LOC:                    40 |       182 |     254 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
ANALYSIS
./grass6/db/base/execute.c functions
main (Begins at: 27 Ends at: 81)
Complexity:   |       9 |       |      OK |
CalledNBR:    |      26 |       |      OK |
LOC:          |      55 |       |      OK |
metrics are OK
parse_command_line (Begins at: 84 Ends at: 137)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      54 |       |      OK |
metrics are OK
get_stmt (Begins at: 140 Ends at: 167)
CalledNBR:    |       8 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
stmt_is_empty (Begins at: 170 Ends at: 176)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
Clone analysis:
Brought to you by:
