SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue Apr 4 14:39:17 EDT 2006
Hello cho,
Threshold GRASS6 key metrics values at 2006-04-04 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 78 |
LOC: 40 | 182 | 254 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
ANALYSIS
./grass6/db/base/select.c functions
main (Begins at: 37 Ends at: 92)
Complexity: | 9 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 24 | | OK |
LOC: | 56 | | OK |
metrics are OK
sel (Begins at: 95 Ends at: 165)
Complexity: | 14 | | OK |
CalledNBR: | 25 | | OK |
LOC: | 71 | | OK |
metrics are OK
parse_command_line (Begins at: 168 Ends at: 272)
Complexity: | 8 | | OK |
CalledNBR: | 32 | | OK |
LOC: | 105 | | OK |
metrics are OK
get_stmt (Begins at: 275 Ends at: 296)
Complexity: | 3 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 22 | | OK |
metrics are OK
stmt_is_empty (Begins at: 299 Ends at: 304)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 6 | | OK |
metrics are OK
print_column_definition (Begins at: 307 Ends at: 316)
Complexity: | 2 | | OK |
CalledNBR: | 12 | | OK |
LOC: | 10 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Brought to you by:
