SOCCER LAB GRASS QA: no clones 3 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue Apr 4 14:58:26 EDT 2006
Hello cho,
Threshold GRASS6 key metrics values at 2006-04-04 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 78 |
LOC: 40 | 182 | 254 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
ANALYSIS
./grass6/ps/ps.map/main.c functions
main (Begins at: 58 Ends at: 717)
Complexity: | 96 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 231 | *** | MONSTER |
LOC: | 660 | *** | MONSTER |
3 metric are OUT OF RANGE!
usage (Begins at: 721 Ends at: 725)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 5 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Brought to you by:
