SOCCER LAB GRASS QA: no clones 3 monsters and 1 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Apr 4 16:02:57 EDT 2006
Hello markus,
Threshold GRASS6 key metrics values at 2006-04-04 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      78 |
LOC:                    40 |       182 |     254 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
ANALYSIS
./grass6/vector/v.to.rast/main.c functions
main (Begins at: 25 Ends at: 115)
Complexity:   |      12 |       |      OK |
CalledNBR:    |      30 |       |      OK |
LOC:          |      91 |       |      OK |
metrics are OK
Clone analysis:
Brought to you by:
