SOCCER LAB GRASS QA: no clones 3 monsters and 1 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue Apr 4 16:02:57 EDT 2006
Hello markus,
Threshold GRASS6 key metrics values at 2006-04-04 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 78 |
LOC: 40 | 182 | 254 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
ANALYSIS
./grass6/vector/v.patch/main.c functions
main (Begins at: 43 Ends at: 365)
Complexity: | 37 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 99 | *** | MONSTER |
LOC: | 323 | *** | MONSTER |
3 metric are OUT OF RANGE!
copy_records (Begins at: 368 Ends at: 462)
Complexity: | 16 | * | |
ParamNBR: | 6 | * | |
CalledNBR: | 42 | * | |
LOC: | 95 | | OK |
at least 1 values are close to an outlier please consider revising code
patch (Begins at: 464 Ends at: 503)
Complexity: | 5 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 40 | | OK |
metrics are OK
max_cat (Begins at: 505 Ends at: 524)
Complexity: | 3 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 20 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Brought to you by:
