SOCCER LAB GRASS QA: 1 clones ( main.c ) 3 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Wed Apr 5 21:06:08 EDT 2006
Hello glynn,
Threshold GRASS6 key metrics values at 2006-04-05 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 78 |
LOC: 40 | 182 | 254 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
ANALYSIS
./grass6/raster/r.resamp.rst/main.c functions
main (Begins at: 132 Ends at: 592)
Complexity: | 64 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 180 | *** | MONSTER |
LOC: | 461 | *** | MONSTER |
3 metric are OUT OF RANGE!
create_temp_files (Begins at: 594 Ends at: 680)
Complexity: | 20 | * | |
ParamNBR: | 1 | | OK |
CalledNBR: | 50 | * | |
LOC: | 87 | | OK |
metrics are OK
clean_fatal_error (Begins at: 682 Ends at: 709)
Complexity: | 7 | | OK |
CalledNBR: | 13 | | OK |
LOC: | 28 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
clean_fatal_error
Brought to you by:
