SOCCER LAB GRASS QA: 1 clones ( main.c ) 3 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Wed Apr 5 23:32:13 EDT 2006
Hello cedric,
Threshold GRASS6 key metrics values at 2006-04-05 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      78 |
LOC:                    40 |       182 |     254 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
ANALYSIS
./grass6/general/g.region/cmd/main.c functions
main (Begins at: 31 Ends at: 772)
Complexity:   |     105 |   *** | MONSTER |
CalledNBR:    |     223 |   *** | MONSTER |
LOC:          |     742 |   *** | MONSTER |
3 metric are OUT OF RANGE!
die (Begins at: 774 Ends at: 780)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
nsew (Begins at: 782 Ends at: 788)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
llinfo (Begins at: 790 Ends at: 798)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  nsew
Brought to you by:
