SOCCER LAB GRASS QA: 1 clones ( main.c ) 2 monsters and 2 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Thu Apr 6 04:05:00 EDT 2006
Hello hamish,
Threshold GRASS6 key metrics values at 2006-04-06 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      78 |
LOC:                    40 |       182 |     254 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
ANALYSIS
./grass6/display/d.nviz/main.c functions
main (Begins at: 43 Ends at: 394)
Complexity:   |      26 |    ** | Warning |
CalledNBR:    |     156 |   *** | MONSTER |
LOC:          |     352 |   *** | MONSTER |
2 metric are OUT OF RANGE!
do_profile (Begins at: 401 Ends at: 470)
Complexity:   |      10 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      29 |       |      OK |
LOC:          |      70 |       |      OK |
at least 1 values are close to an outlier please consider revising code
move (Begins at: 473 Ends at: 478)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
cont (Begins at: 480 Ends at: 501)
Complexity:   |       5 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
read_rast (Begins at: 508 Ends at: 611)
Complexity:   |      15 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |      24 |       |      OK |
LOC:          |     104 |       |      OK |
Clone analysis:
This file has 1 potentially cloned functions:
  cont
Brought to you by:
