SOCCER LAB GRASS QA: no clones 3 monsters and 1 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Apr 11 04:49:59 EDT 2006
Hello radim,
Threshold GRASS6 key metrics values at 2006-04-11 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      78 |
LOC:                    40 |       182 |     254 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
ANALYSIS
./grass6/vector/v.kernel/main.c functions
L (Begins at: 37 Ends at: 61)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
main (Begins at: 64 Ends at: 400)
Complexity:   |      29 |    ** | Warning |
CalledNBR:    |     131 |   *** | MONSTER |
LOC:          |     337 |   *** | MONSTER |
2 metric are OUT OF RANGE!
read_points (Begins at: 404 Ends at: 433)
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
compute_all_distances (Begins at: 438 Ends at: 462)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
compute_all_net_distances (Begins at: 467 Ends at: 534)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      17 |       |      OK |
LOC:          |      68 |       |      OK |
metrics are OK
compute_net_distance (Begins at: 538 Ends at: 585)
ParamNBR:     |       9 |   *** | MONSTER |
CalledNBR:    |      10 |       |      OK |
LOC:          |      48 |       |      OK |
1 metric are OUT OF RANGE!
compute_distance (Begins at: 587 Ends at: 633)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |       8 |       |      OK |
LOC:          |      47 |       |      OK |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Brought to you by:
