SOCCER LAB GRASS QA: 2 clones ( cats.c ) 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Wed Apr 12 03:27:23 EDT 2006
Hello cho,
Threshold GRASS6 key metrics values at 2006-04-12 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 78 |
LOC: 40 | 182 | 256 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
ANALYSIS
./grass6/lib/vector/Vlib/cats.c functions
Vect_new_cats_struct (Begins at: 37 Ends at: 45)
Complexity: | 2 | | OK |
ParamNBR: | 0 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 9 | | OK |
metrics are OK
Vect__new_cats_struct (Begins at: 48 Ends at: 62)
Complexity: | 3 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 15 | | OK |
metrics are OK
Vect_destroy_cats_struct (Begins at: 71 Ends at: 95)
ParamNBR: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 25 | | OK |
metrics are OK
Vect_cat_set (Begins at: 98 Ends at: 143)
Complexity: | 5 | | OK |
ParamNBR: | 3 | | OK |
LOC: | 46 | | OK |
metrics are OK
Vect_cat_get (Begins at: 146 Ends at: 177)
CalledNBR: | 0 | | OK |
LOC: | 32 | | OK |
metrics are OK
Vect_cat_del (Begins at: 180 Ends at: 212)
ParamNBR: | 2 | | OK |
LOC: | 33 | | OK |
metrics are OK
Vect_field_cat_del (Begins at: 215 Ends at: 246)
LOC: | 32 | | OK |
metrics are OK
Vect_reset_cats (Begins at: 249 Ends at: 254)
Complexity: | 1 | | OK |
LOC: | 6 | | OK |
metrics are OK
Vect_new_cat_list (Begins at: 263 Ends at: 286)
LOC: | 24 | | OK |
metrics are OK
Vect_destroy_cat_list (Begins at: 289 Ends at: 311)
LOC: | 23 | | OK |
metrics are OK
Vect_str_to_cat_list (Begins at: 314 Ends at: 384)
Complexity: | 8 | | OK |
CalledNBR: | 13 | | OK |
LOC: | 71 | | OK |
metrics are OK
Vect_array_to_cat_list (Begins at: 393 Ends at: 424)
LOC: | 32 | | OK |
metrics are OK
Vect_cat_in_cat_list (Begins at: 433 Ends at: 442)
LOC: | 10 | | OK |
metrics are OK
Vect_cat_in_array (Begins at: 451 Ends at: 461)
LOC: | 11 | | OK |
metrics are OK
cmp (Begins at: 464 Ends at: 474)
LOC: | 11 | | OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
Vect_new_cats_struct Vect__new_cats_struct
Brought to you by:
