SOCCER LAB GRASS QA: no clones 3 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Wed Apr 19 03:30:50 EDT 2006
Hello hamish,
Threshold GRASS6 key metrics values at 2006-04-19 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 78 |
LOC: 40 | 182 | 256 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
ANALYSIS
./grass6/raster/r.drain/main.c functions
main (Begins at: 68 Ends at: 443)
Complexity: | 33 | ** | Warning |
ParamNBR: | 8 | ** | Warning |
CalledNBR: | 123 | *** | MONSTER |
LOC: | 376 | *** | MONSTER |
3 metric are OUT OF RANGE!
drain (Begins at: 445 Ends at: 502)
Complexity: | 8 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 58 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Brought to you by:
