SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Wed Apr 19 09:20:10 EDT 2006
Hello markus,
Threshold GRASS6 key metrics values at 2006-04-19 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      78 |
LOC:                    40 |       182 |     256 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
ANALYSIS
./grass6/db/base/drivers.c functions
main (Begins at: 16 Ends at: 34)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
parse_command_line (Begins at: 37 Ends at: 61)
Complexity:   |       2 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
Clone analysis:
Brought to you by:
