[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue Apr 25 14:20:50 EDT 2006
Hello brad,
ANALYSIS
vector/v.digit/main.c functions
Tcl_AppInit (Begins at: 29 Ends at: 88)
Complexity: | 5 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 26 | | OK |
LOC: | 60 | | OK |
metrics are OK
main (Begins at: 91 Ends at: 200)
Complexity: | 7 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 49 | * | |
LOC: | 110 | | OK |
metrics are OK
end (Begins at: 203 Ends at: 211)
Complexity: | 1 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 9 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-04-25 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 78 |
LOC: 40 | 182 | 256 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
