[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Apr 25 14:27:00 EDT 2006
Hello brad,
ANALYSIS
vector/v.digit/main.c functions
Tcl_AppInit (Begins at: 29 Ends at: 88)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      26 |       |      OK |
LOC:          |      60 |       |      OK |
metrics are OK
main (Begins at: 91 Ends at: 200)
Complexity:   |       7 |       |      OK |
CalledNBR:    |      49 |     * |         |
LOC:          |     110 |       |      OK |
metrics are OK
end (Begins at: 203 Ends at: 211)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-04-25 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      78 |
LOC:                    40 |       182 |     256 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
