[GRASS-QA] GRASS QA: glynn | ./grass6/display/drivers/lib/clip.c |1 clones ( clip.c )| 0 monsters | 1 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Aug 1 18:10:47 EDT 2006
Hello glynn,
ANALYSIS
display/drivers/lib/clip.c functions
clip (Begins at: 20 Ends at: 84)
Complexity:   |      17 |     * |         |
ParamNBR:     |       8 |    ** | Warning |
CalledNBR:    |       0 |       |      OK |
LOC:          |      65 |       |      OK |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file has 1 potentially cloned functions:
  clip
In display/drivers/lib/clip.c clones of  clip are:
	lib/driver/clip.c  clip
Threshold GRASS6 key metrics values at 2006-08-01 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
