[GRASS-QA] GRASS QA: glynn | ./grass6/display/drivers/lib/Color.c
|1 clones ( clip.c Color.c )| 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue Aug 1 18:10:47 EDT 2006
Hello glynn,
ANALYSIS
display/drivers/lib/Color.c functions
DRV_lookup_color (Begins at: 10 Ends at: 15)
Complexity: | 2 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 6 | | OK |
metrics are OK
DRV_color (Begins at: 17 Ends at: 21)
ParamNBR: | 1 | | OK |
LOC: | 5 | | OK |
metrics are OK
COM_Color (Begins at: 23 Ends at: 26)
Complexity: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 4 | | OK |
metrics are OK
COM_Color_RGB (Begins at: 28 Ends at: 32)
LOC: | 5 | | OK |
metrics are OK
COM_Standard_color (Begins at: 34 Ends at: 40)
CalledNBR: | 4 | | OK |
LOC: | 7 | | OK |
metrics are OK
COM_Color_offset (Begins at: 42 Ends at: 45)
CalledNBR: | 0 | | OK |
LOC: | 4 | | OK |
metrics are OK
LIB_get_color_index (Begins at: 47 Ends at: 73)
Complexity: | 5 | | OK |
LOC: | 27 | | OK |
metrics are OK
LIB_get_color_index_array (Begins at: 75 Ends at: 109)
LOC: | 35 | | OK |
metrics are OK
get_color_offset (Begins at: 111 Ends at: 114)
LOC: | 4 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
In display/drivers/lib/Color.c clones of LIB_get_color_index_array are:
lib/driver/Color.c LIB_get_color_index_array
Threshold GRASS6 key metrics values at 2006-08-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
