[GRASS-QA] GRASS QA: glynn | ./grass6/display/drivers/lib/command.c |2 clones ( clip.c Color.c command.c )| 3 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Aug 1 18:10:47 EDT 2006
Hello glynn,
ANALYSIS
display/drivers/lib/command.c functions
xalloc (Begins at: 58 Ends at: 67)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
command_init (Begins at: 69 Ends at: 78)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
LIB_command_get_input (Begins at: 80 Ends at: 83)
ParamNBR:     |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
process_command (Begins at: 85 Ends at: 618)
Complexity:   |     218 |   *** | MONSTER |
CalledNBR:    |     283 |   *** | MONSTER |
LOC:          |     534 |   *** | MONSTER |
3 metric are OUT OF RANGE!
read1 (Begins at: 620 Ends at: 633)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
get_command (Begins at: 635 Ends at: 661)
Complexity:   |       7 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
get1 (Begins at: 663 Ends at: 678)
Complexity:   |       5 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
rec (Begins at: 680 Ends at: 689)
Complexity:   |       3 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
rectext (Begins at: 691 Ends at: 715)
LOC:          |      25 |       |      OK |
metrics are OK
_send (Begins at: 717 Ends at: 733)
LOC:          |      17 |       |      OK |
metrics are OK
sendtext (Begins at: 735 Ends at: 739)
LOC:          |       5 |       |      OK |
metrics are OK
RESULT (Begins at: 741 Ends at: 749)
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  command_init  xalloc
In display/drivers/lib/command.c clones of  xalloc are:
	lib/driver/command.c  xalloc
In display/drivers/lib/command.c clones of  command_init are:
	lib/driver/command.c  command_init
Threshold GRASS6 key metrics values at 2006-08-01 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
