[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.lrs/lib/lrs.c |no clones | 3 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Thu Aug 3 05:10:39 EDT 2006
Hello markus,
ANALYSIS
vector/v.lrs/lib/lrs.c functions
cmp_rsegment (Begins at: 46 Ends at: 59)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
LR_get_milepost (Begins at: 61 Ends at: 232)
Complexity:   |      11 |       |      OK |
ParamNBR:     |      16 |   *** | MONSTER |
CalledNBR:    |      45 |     * |         |
LOC:          |     172 |     * |         |
1 metric are OUT OF RANGE!
LR_get_offset (Begins at: 234 Ends at: 267)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      34 |       |      OK |
offset_in_rsegment (Begins at: 269 Ends at: 332)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       8 |       |      OK |
LOC:          |      64 |       |      OK |
metrics are OK
LR_get_nearest_offset (Begins at: 334 Ends at: 563)
Complexity:   |      20 |     * |         |
ParamNBR:     |      17 |   *** | MONSTER |
CalledNBR:    |      56 |    ** | Warning |
LOC:          |     230 |    ** | Warning |
LR_cmp_mileposts (Begins at: 570 Ends at: 596)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-03 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
