[GRASS-QA] GRASS QA: markus |
./grass6/visualization/nviz/src/pick_vect_commands.c |no
clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Thu Aug 3 05:10:40 EDT 2006
Hello markus,
ANALYSIS
visualization/nviz/src/pick_vect_commands.c functions
pick_init_tcl (Begins at: 128 Ends at: 131)
Complexity: | 1 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 4 | | OK |
metrics are OK
Npick_vect_cmd (Begins at: 136 Ends at: 176)
Complexity: | 4 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 41 | | OK |
metrics are OK
query_vect_cats (Begins at: 179 Ends at: 222)
Complexity: | 7 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 11 | | OK |
LOC: | 44 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-08-03 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
