[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.lrs/lib/lrs.c |no
clones | 3 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Thu Aug 3 05:21:18 EDT 2006
Hello markus,
ANALYSIS
vector/v.lrs/lib/lrs.c functions
cmp_rsegment (Begins at: 46 Ends at: 59)
Complexity: | 1 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 14 | | OK |
metrics are OK
LR_get_milepost (Begins at: 61 Ends at: 232)
Complexity: | 11 | | OK |
ParamNBR: | 16 | *** | MONSTER |
CalledNBR: | 45 | * | |
LOC: | 172 | * | |
1 metric are OUT OF RANGE!
LR_get_offset (Begins at: 234 Ends at: 267)
Complexity: | 2 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 34 | | OK |
offset_in_rsegment (Begins at: 269 Ends at: 332)
Complexity: | 3 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 8 | | OK |
LOC: | 64 | | OK |
metrics are OK
LR_get_nearest_offset (Begins at: 334 Ends at: 563)
Complexity: | 20 | * | |
ParamNBR: | 17 | *** | MONSTER |
CalledNBR: | 56 | ** | Warning |
LOC: | 230 | ** | Warning |
LR_cmp_mileposts (Begins at: 570 Ends at: 596)
Complexity: | 5 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 27 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-08-03 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
