[GRASS-QA] GRASS QA: soeren | ./grass6/lib/g3d/g3dopen.c |no clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Mon Aug 7 09:53:17 EDT 2006
Hello soeren,
ANALYSIS
lib/g3d/g3dopen.c functions
G3d_openCellOldNoHeader (Begins at: 13 Ends at: 84)
Complexity:   |       5 |       |      OK |
CalledNBR:    |      20 |       |      OK |
LOC:          |      72 |       |      OK |
metrics are OK
G3d_openCellOld (Begins at: 87 Ends at: 214)
Complexity:   |      14 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      34 |     * |         |
LOC:          |     128 |     * |         |
metrics are OK
G3d_openCellNew (Begins at: 217 Ends at: 331)
Complexity:   |      18 |     * |         |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      33 |     * |         |
LOC:          |     115 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-07 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
