[GRASS-QA] GRASS QA: cho | ./grass6/lib/fonts/for_grass/splitfont.c
|no clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Mon Aug 7 18:11:55 EDT 2006
Hello cho,
ANALYSIS
lib/fonts/for_grass/splitfont.c functions
main (Begins at: 8 Ends at: 124)
Complexity: | 9 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 34 | * | |
LOC: | 117 | * | |
metrics are OK
savechar (Begins at: 126 Ends at: 140)
Complexity: | 1 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 15 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-08-07 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
