[GRASS-QA] GRASS QA: soeren | ./grass6/raster/r.le/r.le.patch/main.c |no clones | 1 monsters | 0 warnings
Mon Aug 14 14:49:24 EDT 2006
Hello soeren,
ANALYSIS
raster/r.le/r.le.patch/main.c functions
main (Begins at: 35 Ends at: 153)
Complexity:   |      60 |   *** | MONSTER |
CalledNBR:    |      69 |    ** | Warning |
LOC:          |     119 |     * |         |
1 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-14 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
