[GRASS-QA] GRASS QA: cho | ./grass6/raster/r.colors/rules.c |no clones | 1 monsters | 0 warnings
Tue Aug 15 17:33:37 EDT 2006
Hello cho,
ANALYSIS
raster/r.colors/rules.c functions
read_color_rules (Begins at: 27 Ends at: 160)
Complexity:   |      23 |     * |         |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |      23 |       |      OK |
LOC:          |     134 |     * |         |
metrics are OK
read_rule (Begins at: 162 Ends at: 400)
Complexity:   |      32 |    ** | Warning |
ParamNBR:     |      10 |   *** | MONSTER |
CalledNBR:    |      68 |    ** | Warning |
LOC:          |     239 |    ** | Warning |
1 metric are OUT OF RANGE!
badrule (Begins at: 402 Ends at: 412)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
lookup_color (Begins at: 414 Ends at: 432)
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       6 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
show_colors (Begins at: 434 Ends at: 455)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-15 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
