[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.to.vect/areas_io.c |no clones | 0 monsters | 0 warnings
Wed Aug 16 18:44:50 EDT 2006
Hello glynn,
ANALYSIS
raster/r.to.vect/areas_io.c functions
write_boundary (Begins at: 35 Ends at: 75)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      41 |       |      OK |
metrics are OK
write_bnd (Begins at: 80 Ends at: 146)
Complexity:   |      13 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      67 |       |      OK |
metrics are OK
write_smooth_bnd (Begins at: 153 Ends at: 254)
Complexity:   |      15 |       |      OK |
CalledNBR:    |      16 |       |      OK |
LOC:          |     102 |       |      OK |
metrics are OK
write_area (Begins at: 257 Ends at: 373)
Complexity:   |      17 |     * |         |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      30 |       |      OK |
LOC:          |     117 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-16 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
