[GRASS-QA] GRASS QA: glynn | ./grass6/vector/v.out.dxf/main.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Aug 16 18:44:50 EDT 2006
Hello glynn,
ANALYSIS
vector/v.out.dxf/main.c functions
main (Begins at: 34 Ends at: 89)
Complexity: | 4 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 26 | | OK |
LOC: | 56 | | OK |
metrics are OK
do_limits (Begins at: 91 Ends at: 108)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 18 | | OK |
metrics are OK
make_layername (Begins at: 110 Ends at: 130)
Complexity: | 1 | | OK |
CalledNBR: | 14 | | OK |
LOC: | 21 | | OK |
metrics are OK
add_plines (Begins at: 132 Ends at: 189)
Complexity: | 6 | | OK |
CalledNBR: | 12 | | OK |
LOC: | 58 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-08-16 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
