[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.contour/main.c |no clones | 0 monsters | 2 warnings
Sat Aug 19 09:20:42 EDT 2006
Hello markus,
ANALYSIS
raster/r.contour/main.c functions
main (Begins at: 37 Ends at: 193)
Complexity:   |      11 |       |      OK |
CalledNBR:    |      73 |    ** | Warning |
LOC:          |     157 |     * |         |
at least 1 values are close to an outlier please consider revising code
get_z_array (Begins at: 196 Ends at: 216)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
getlevels (Begins at: 220 Ends at: 323)
Complexity:   |      12 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      19 |       |      OK |
LOC:          |     104 |       |      OK |
displaceMatrix (Begins at: 331 Ends at: 359)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       3 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-19 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
