[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.composite/main.c |no clones | 0 monsters | 2 warnings
Sat Aug 19 09:20:42 EDT 2006
Hello markus,
ANALYSIS
raster/r.composite/main.c functions
main (Begins at: 48 Ends at: 293)
Complexity:   |      13 |       |      OK |
CalledNBR:    |      67 |    ** | Warning |
LOC:          |     246 |    ** | Warning |
at least 2 values are close to an outlier please consider revising code
quantize (Begins at: 295 Ends at: 300)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
make_color_cube (Begins at: 302 Ends at: 335)
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-19 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
