[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.null/null.c |1
clones ( main.c main.c main.c parser.c main.c main.c main.c
main.c main.c main.c main.c null.c )| 0 monsters | 2 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Aug 19 11:21:39 EDT 2006
Hello markus,
ANALYSIS
raster/r.null/null.c functions
main (Begins at: 13 Ends at: 214)
Complexity: | 16 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 65 | ** | Warning |
LOC: | 202 | ** | Warning |
at least 2 values are close to an outlier please consider revising code
parse_vallist (Begins at: 216 Ends at: 249)
Complexity: | 6 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 34 | | OK |
metrics are OK
parse_d_mask_rule (Begins at: 252 Ends at: 285)
ParamNBR: | 3 | | OK |
CalledNBR: | 13 | | OK |
LOC: | 34 | | OK |
metrics are OK
process (Begins at: 288 Ends at: 330)
Complexity: | 7 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 15 | | OK |
LOC: | 43 | | OK |
metrics are OK
doit (Begins at: 333 Ends at: 392)
CalledNBR: | 25 | | OK |
LOC: | 60 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
parse_vallist
In raster/r.null/null.c clones of parse_vallist are:
display/d.rast/main.c parse_vallist
display/d.rast/main.c parse_catlist
Threshold GRASS6 key metrics values at 2006-08-19 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
