[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.neighbors/main.c |no clones | 0 monsters | 2 warnings
Sat Aug 19 11:21:39 EDT 2006
Hello markus,
ANALYSIS
raster/r.neighbors/main.c functions
main (Begins at: 43 Ends at: 279)
Complexity:   |      21 |     * |         |
CalledNBR:    |      78 |    ** | Warning |
LOC:          |     237 |    ** | Warning |
at least 2 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-19 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
