[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.flow/io.c |no clones | 0 monsters | 2 warnings
Sat Aug 19 11:21:38 EDT 2006
Hello markus,
ANALYSIS
raster/r.flow/io.c functions
tmp_name (Begins at: 40 Ends at: 53)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
parameter (Begins at: 58 Ends at: 74)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |       1 |       |      OK |
LOC:          |      17 |       |      OK |
at least 1 values are close to an outlier please consider revising code
flag (Begins at: 77 Ends at: 86)
Complexity:   |       1 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
parse_command_line (Begins at: 89 Ends at: 225)
Complexity:   |       7 |       |      OK |
CalledNBR:    |      80 |   *** | MONSTER |
LOC:          |     137 |     * |         |
diag (Begins at: 228 Ends at: 236)
CalledNBR:    |       2 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
open_existing_cell_file (Begins at: 239 Ends at: 251)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
read_input_files (Begins at: 254 Ends at: 315)
Complexity:   |      10 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |      26 |       |      OK |
LOC:          |      62 |       |      OK |
metrics are OK
open_segment_file (Begins at: 318 Ends at: 346)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      14 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
open_output_files (Begins at: 349 Ends at: 370)
Complexity:   |       5 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
close_files (Begins at: 373 Ends at: 391)
LOC:          |      19 |       |      OK |
metrics are OK
write_density_file (Begins at: 394 Ends at: 433)
LOC:          |      40 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-19 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
