[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.grow2/main.c |no clones | 0 monsters | 3 warnings
Sat Aug 19 11:21:38 EDT 2006
Hello markus,
ANALYSIS
raster/r.grow2/main.c functions
distance_euclidian_squared (Begins at: 17 Ends at: 20)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
distance_maximum (Begins at: 22 Ends at: 25)
CalledNBR:    |       4 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
distance_manhattan (Begins at: 27 Ends at: 30)
CalledNBR:    |       2 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
setup_neighbors (Begins at: 32 Ends at: 60)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
setup_neighbors_euclidian (Begins at: 62 Ends at: 67)
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
setup_neighbors_maximum (Begins at: 69 Ends at: 72)
LOC:          |       4 |       |      OK |
metrics are OK
setup_neighbors_manhattan (Begins at: 74 Ends at: 77)
LOC:          |       4 |       |      OK |
metrics are OK
main (Begins at: 79 Ends at: 298)
Complexity:   |      26 |    ** | Warning |
CalledNBR:    |      71 |    ** | Warning |
LOC:          |     220 |    ** | Warning |
at least 3 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-19 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
