[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.net.salesman/main.c
|1 clones ( main.c main.c main.c parser.c main.c main.c
main.c main.c main.c main.c main.c null.c main.c main.c
main.c main.c main.c main.c main.c main.c main.c )| 2
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Aug 19 11:21:49 EDT 2006
Hello markus,
ANALYSIS
vector/v.net.salesman/main.c functions
cnode (Begins at: 42 Ends at: 42)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 1 | | OK |
metrics are OK
add_city (Begins at: 44 Ends at: 65)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 22 | | OK |
metrics are OK
main (Begins at: 68 Ends at: 358)
Complexity: | 19 | * | |
CalledNBR: | 103 | *** | MONSTER |
LOC: | 291 | *** | MONSTER |
2 metric are OUT OF RANGE!
cmp (Begins at: 360 Ends at: 372)
Complexity: | 3 | | OK |
LOC: | 13 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
cmp
In vector/v.net.salesman/main.c clones of cmp are:
vector/v.net.steiner/main.c cmp
Threshold GRASS6 key metrics values at 2006-08-19 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
