[GRASS-QA] GRASS QA: cho | ./grass6/lib/gis/env.c |1 clones ( env.c
)| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Tue Aug 22 06:29:19 EDT 2006
Hello cho,
ANALYSIS
lib/gis/env.c functions
G_set_gisrc_mode (Begins at: 85 Ends at: 88)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 4 | | OK |
metrics are OK
G_get_gisrc_mode (Begins at: 91 Ends at: 94)
LOC: | 4 | | OK |
metrics are OK
read_env (Begins at: 97 Ends at: 160)
Complexity: | 8 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 64 | | OK |
metrics are OK
set_env (Begins at: 162 Ends at: 219)
Complexity: | 7 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 58 | | OK |
metrics are OK
unset_env (Begins at: 221 Ends at: 234)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 14 | | OK |
metrics are OK
get_env (Begins at: 236 Ends at: 246)
CalledNBR: | 1 | | OK |
LOC: | 11 | | OK |
metrics are OK
write_env (Begins at: 248 Ends at: 306)
Complexity: | 4 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 59 | | OK |
metrics are OK
open_env (Begins at: 308 Ends at: 335)
Complexity: | 5 | | OK |
CalledNBR: | 9 | | OK |
LOC: | 28 | | OK |
metrics are OK
G_getenv (Begins at: 337 Ends at: 346)
CalledNBR: | 3 | | OK |
LOC: | 10 | | OK |
metrics are OK
G_getenv2 (Begins at: 349 Ends at: 358)
LOC: | 10 | | OK |
metrics are OK
G__getenv (Begins at: 360 Ends at: 368)
CalledNBR: | 4 | | OK |
LOC: | 9 | | OK |
metrics are OK
G__getenv2 (Begins at: 370 Ends at: 378)
LOC: | 9 | | OK |
metrics are OK
G_setenv (Begins at: 380 Ends at: 386)
LOC: | 7 | | OK |
metrics are OK
G_setenv2 (Begins at: 388 Ends at: 394)
LOC: | 7 | | OK |
metrics are OK
G__setenv (Begins at: 396 Ends at: 401)
LOC: | 6 | | OK |
metrics are OK
G__setenv2 (Begins at: 403 Ends at: 408)
LOC: | 6 | | OK |
metrics are OK
G_unsetenv (Begins at: 410 Ends at: 417)
LOC: | 8 | | OK |
metrics are OK
G_unsetenv2 (Begins at: 419 Ends at: 426)
LOC: | 8 | | OK |
metrics are OK
G__write_env (Begins at: 429 Ends at: 435)
LOC: | 7 | | OK |
metrics are OK
G__env_name (Begins at: 437 Ends at: 447)
Complexity: | 3 | | OK |
LOC: | 11 | | OK |
metrics are OK
G__read_env (Begins at: 449 Ends at: 454)
LOC: | 6 | | OK |
metrics are OK
G__set_gisrc_file (Begins at: 456 Ends at: 463)
LOC: | 8 | | OK |
metrics are OK
G__get_gisrc_file (Begins at: 465 Ends at: 468)
LOC: | 4 | | OK |
metrics are OK
G__create_alt_env (Begins at: 470 Ends at: 485)
LOC: | 16 | | OK |
metrics are OK
G__switch_env (Begins at: 487 Ends at: 502)
LOC: | 16 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
G_setenv2
In lib/gis/env.c clones of G_setenv2 are:
vector/v.digit/i_face.c i_prompt_buttons
Threshold GRASS6 key metrics values at 2006-08-22 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
