[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.extrude/main.c |no clones | 3 monsters | 0 warnings
Tue Aug 22 09:30:02 EDT 2006
Hello martinl,
ANALYSIS
vector/v.extrude/main.c functions
main (Begins at: 37 Ends at: 353)
Complexity:   |      35 |    ** | Warning |
CalledNBR:    |     110 |   *** | MONSTER |
LOC:          |     317 |   *** | MONSTER |
2 metric are OUT OF RANGE!
extrude (Begins at: 359 Ends at: 445)
Complexity:   |       7 |       |      OK |
ParamNBR:     |      10 |   *** | MONSTER |
CalledNBR:    |      13 |       |      OK |
LOC:          |      87 |       |      OK |
1 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-22 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
