[GRASS-QA] GRASS QA: markus | ./grass6/vector/lidar/v.outlier/outlier.c |no clones | 1 monsters | 0 warnings
Tue Aug 22 16:15:53 EDT 2006
Hello markus,
ANALYSIS
vector/lidar/v.outlier/outlier.c functions
P_Outlier (Begins at: 10 Ends at: 180)
Complexity:   |      28 |    ** | Warning |
ParamNBR:     |      13 |   *** | MONSTER |
CalledNBR:    |      60 |    ** | Warning |
LOC:          |     171 |     * |         |
1 metric are OUT OF RANGE!
Insert_Outlier (Begins at: 182 Ends at: 195)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
UpDate_Outlier (Begins at: 197 Ends at: 208)
CalledNBR:    |       4 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
Select_Outlier (Begins at: 210 Ends at: 240)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
P_is_outlier (Begins at: 242 Ends at: 250)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-22 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
