[GRASS-QA] GRASS QA: markus | ./grass6/raster3d/base/r3.null.main.c |no clones | 0 monsters | 0 warnings
Wed Aug 23 07:40:14 EDT 2006
Hello markus,
ANALYSIS
raster3d/base/r3.null.main.c functions
setParams (Begins at: 49 Ends at: 73)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
getParams (Begins at: 78 Ends at: 87)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
modifyNull (Begins at: 92 Ends at: 189)
Complexity:   |      13 |       |      OK |
CalledNBR:    |      47 |     * |         |
LOC:          |      98 |       |      OK |
metrics are OK
main (Begins at: 193 Ends at: 214)
Complexity:   |       2 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-23 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
