[GRASS-QA] GRASS QA: markus | ./grass6/raster3d/base/r3.mask.main.c |no clones | 0 monsters | 0 warnings
Wed Aug 23 07:40:13 EDT 2006
Hello markus,
ANALYSIS
raster3d/base/r3.mask.main.c functions
setParams (Begins at: 36 Ends at: 53)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
getParams (Begins at: 57 Ends at: 61)
CalledNBR:    |       1 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
makeMask (Begins at: 67 Ends at: 140)
Complexity:   |      11 |       |      OK |
CalledNBR:    |      43 |     * |         |
LOC:          |      74 |       |      OK |
metrics are OK
main (Begins at: 144 Ends at: 169)
Complexity:   |       3 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-23 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
