[GRASS-QA] GRASS QA: markus | ./grass6/raster3d/r3.out.vtk/main.c
|3 clones ( main.c main.c main.c main.c main.c main.c main.c
main.c parser.c main.c main.c main.c main.c )| 0 monsters | 2
warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Aug 23 07:40:14 EDT 2006
Hello markus,
ANALYSIS
raster3d/r3.out.vtk/main.c functions
CreateInputMapsStruct (Begins at: 56 Ends at: 81)
Complexity: | 1 | | OK |
ParamNBR: | 0 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 26 | | OK |
metrics are OK
OpenInputMap (Begins at: 86 Ends at: 101)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 16 | | OK |
metrics are OK
CheckInputMaps (Begins at: 107 Ends at: 182)
Complexity: | 14 | | OK |
CalledNBR: | 23 | | OK |
LOC: | 76 | | OK |
metrics are OK
OpenWriteRGBMaps (Begins at: 188 Ends at: 266)
Complexity: | 19 | * | |
ParamNBR: | 4 | | OK |
CalledNBR: | 20 | | OK |
LOC: | 79 | | OK |
metrics are OK
OpenWriteVectorMaps (Begins at: 271 Ends at: 349)
LOC: | 79 | | OK |
metrics are OK
main (Begins at: 355 Ends at: 557)
Complexity: | 24 | * | |
CalledNBR: | 67 | ** | Warning |
LOC: | 203 | ** | Warning |
at least 2 values are close to an outlier please consider revising code
Clone analysis:
This file has 3 potentially cloned functions:
OpenInputMap OpenWriteVectorMaps OpenWriteRGBMaps
In raster3d/r3.out.vtk/main.c clones of OpenWriteVectorMaps are:
raster3d/r3.out.vtk/main.c OpenWriteRGBMaps
In raster3d/r3.out.vtk/main.c clones of OpenInputMap are:
raster/r.to.rast3/main.c open_input_raster_map
In raster3d/r3.out.vtk/main.c clones of OpenWriteRGBMaps are:
raster3d/r3.out.vtk/main.c OpenWriteVectorMaps
Threshold GRASS6 key metrics values at 2006-08-23 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
