[GRASS-QA] GRASS QA: markus | ./grass6/raster3d/r3.to.rast/main.c
|1 clones ( main.c main.c main.c main.c main.c main.c main.c
main.c parser.c main.c main.c main.c main.c main.c )| 0
monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Aug 23 07:40:14 EDT 2006
Hello markus,
ANALYSIS
raster3d/r3.to.rast/main.c functions
fatalError (Begins at: 49 Ends at: 67)
Complexity: | 4 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 19 | | OK |
metrics are OK
setParams (Begins at: 73 Ends at: 100)
Complexity: | 1 | | OK |
ParamNBR: | 0 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 28 | | OK |
metrics are OK
G3dToRaster (Begins at: 107 Ends at: 177)
Complexity: | 12 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 24 | | OK |
LOC: | 71 | | OK |
metrics are OK
main (Begins at: 183 Ends at: 343)
Complexity: | 21 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 62 | ** | Warning |
LOC: | 161 | * | |
at least 1 values are close to an outlier please consider revising code
open_output_map (Begins at: 350 Ends at: 359)
Complexity: | 2 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 10 | | OK |
metrics are OK
close_output_map (Begins at: 364 Ends at: 368)
ParamNBR: | 1 | | OK |
LOC: | 5 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
setParams
In raster3d/r3.to.rast/main.c clones of setParams are:
raster3d/r3.cross.rast/main.c SetParameter
Threshold GRASS6 key metrics values at 2006-08-23 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
