[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.grow2/main.c |no
clones | 0 monsters | 3 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Aug 23 07:40:16 EDT 2006
Hello markus,
ANALYSIS
raster/r.grow2/main.c functions
distance_euclidian_squared (Begins at: 17 Ends at: 20)
Complexity: | 1 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 4 | | OK |
metrics are OK
distance_maximum (Begins at: 22 Ends at: 25)
CalledNBR: | 4 | | OK |
LOC: | 4 | | OK |
metrics are OK
distance_manhattan (Begins at: 27 Ends at: 30)
CalledNBR: | 2 | | OK |
LOC: | 4 | | OK |
metrics are OK
setup_neighbors (Begins at: 32 Ends at: 60)
Complexity: | 2 | | OK |
ParamNBR: | 3 | | OK |
LOC: | 29 | | OK |
metrics are OK
setup_neighbors_euclidian (Begins at: 62 Ends at: 67)
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 6 | | OK |
metrics are OK
setup_neighbors_maximum (Begins at: 69 Ends at: 72)
LOC: | 4 | | OK |
metrics are OK
setup_neighbors_manhattan (Begins at: 74 Ends at: 77)
LOC: | 4 | | OK |
metrics are OK
main (Begins at: 79 Ends at: 298)
Complexity: | 26 | ** | Warning |
CalledNBR: | 71 | ** | Warning |
LOC: | 220 | ** | Warning |
at least 3 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-08-23 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
