[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.flow/io.c |no
clones | 0 monsters | 2 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Aug 23 07:40:16 EDT 2006
Hello markus,
ANALYSIS
raster/r.flow/io.c functions
tmp_name (Begins at: 40 Ends at: 53)
Complexity: | 4 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 14 | | OK |
metrics are OK
parameter (Begins at: 58 Ends at: 74)
Complexity: | 2 | | OK |
ParamNBR: | 7 | ** | Warning |
CalledNBR: | 1 | | OK |
LOC: | 17 | | OK |
at least 1 values are close to an outlier please consider revising code
flag (Begins at: 77 Ends at: 86)
Complexity: | 1 | | OK |
ParamNBR: | 2 | | OK |
LOC: | 10 | | OK |
metrics are OK
parse_command_line (Begins at: 89 Ends at: 225)
Complexity: | 7 | | OK |
CalledNBR: | 80 | *** | MONSTER |
LOC: | 137 | * | |
diag (Begins at: 228 Ends at: 236)
CalledNBR: | 2 | | OK |
LOC: | 9 | | OK |
metrics are OK
open_existing_cell_file (Begins at: 239 Ends at: 251)
Complexity: | 3 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 13 | | OK |
metrics are OK
read_input_files (Begins at: 254 Ends at: 315)
Complexity: | 10 | | OK |
ParamNBR: | 0 | | OK |
CalledNBR: | 26 | | OK |
LOC: | 62 | | OK |
metrics are OK
open_segment_file (Begins at: 318 Ends at: 346)
Complexity: | 6 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 14 | | OK |
LOC: | 29 | | OK |
metrics are OK
open_output_files (Begins at: 349 Ends at: 370)
Complexity: | 5 | | OK |
CalledNBR: | 13 | | OK |
LOC: | 22 | | OK |
metrics are OK
close_files (Begins at: 373 Ends at: 391)
LOC: | 19 | | OK |
metrics are OK
write_density_file (Begins at: 394 Ends at: 433)
LOC: | 40 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-08-23 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
