[GRASS-QA] GRASS QA: markus | ./grass6/general/g.pnmcomp/main.c |no clones | 0 monsters | 0 warnings
Wed Aug 23 07:40:10 EDT 2006
Hello markus,
ANALYSIS
general/g.pnmcomp/main.c functions
erase (Begins at: 28 Ends at: 46)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
read_line (Begins at: 49 Ends at: 59)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       3 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
read_header (Begins at: 62 Ends at: 86)
Complexity:   |       5 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
read_pnm (Begins at: 89 Ends at: 173)
Complexity:   |      20 |     * |         |
CalledNBR:    |      15 |       |      OK |
LOC:          |      85 |       |      OK |
metrics are OK
overlay (Begins at: 176 Ends at: 210)
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      35 |       |      OK |
metrics are OK
overlay_alpha (Begins at: 213 Ends at: 241)
LOC:          |      29 |       |      OK |
metrics are OK
write_ppm (Begins at: 244 Ends at: 259)
CalledNBR:    |       6 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
main (Begins at: 262 Ends at: 365)
Complexity:   |       7 |       |      OK |
CalledNBR:    |      25 |       |      OK |
LOC:          |     104 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-23 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
